Double tap to wake
DMaino
Double tap to wake
Does anybody tried this out? It works 1/10 on mine. Any suggestion ? Thanks.
23 REPLIES 23
Abe9
The feature double tap to wake up is not working properly on my phone!! Any other bad experience with it?!?!
Thanks
Abe
Tags (1)
04fuxake
I had this problem and solved it by simply setting my cover selection to "No Cover". This has been confirmed by another user on Reddit.
I suspect there is a bug when there is no default setting under Settings - Display - Cover Selection. Without this set, the OS doesn't know how the screen is being woken up. The fact that you can't unset this setting once an option is selected makes me think it's not intended to be unselected.
Mauro88
What's your android version/build? I can't find the "Cover selection" setting you mentioned. Thanks.
04fuxake
Android 7.1.1
Settings -> Display -> Cover Selection
Having said that, I've found my fix doesn't seem to work in the latest version.
