End of call loud tone
Dan35
This just started happening lately, every time a call ends the usual noise when a call ends happens but it's really loud now coming from both speakers as of the call is on speaker phone but it never is. Is a software update going to fix this?
Tags (3)
3 REPLIES 3
Jonas
Master
Hi @Dan35, very sorry to hear about this, must be very inconvenient. Slightly_frowning_Face
Can you remember if you installed a new application or installed a new update just prior to you starting to experience this behaviour?
I would recommend that you start with rebooting your phone in safe mode and make a few calls when third party applications aren't loaded. That way we can make sure that one of your downloaded applications isn't the cause of this noise being played at such a high volume.
Let me know how it went! Slightly_smiling_Face
profile.country.PL.title
najodleglejszy
if you haven't solved it yet - one of the apps causing that is Snapchat. you can go to Settings > Apps > Snapchat > Permissions and deny Telephone permission. the app will work fine, but the loud beep will be gone.
Jonas
Master
That is a great suggestion @najodleglejszy!
Thanks a lot for this and I hope @Dan35 will find this information helpful! Slightly_smiling_Face
