Front camera is not working and volte not supported
jomon11
Hi, I am using xperia x duel and my front camera is not working. Screen has black and some times front camera is not found.if found only just switch off then switch on, and my phone is does not support volte features. What can I do
1 REPLY 1
YoGem
Leader
@jomon11 well, first of all you should check that your phone is compatible with your network LTE bands and that your sim card is VoLTE enabled. About the other issues you should try restarting your phone in safe mode or performing a software repair using Xperia Companion.
