How to increase max volume of speakers?
Олег33
Translation via Google translate:
How to get into the engineering menu X Compact? How or what needs to be done in order to raise the volume level with an incoming call ???
как попасть в инженерное меню X Compact? как или что нужно сделать для того что бы поднять уровень громкости при входящем звонке???
1 REPLY 1
Emil
Enthusiast
Hi @Олег33,
As this is an International community your previous post has been translated in to English using Google translate, please keep all future post in English.
There is no setting to increase the volume of your device other then using the volume key on the side of your device.
Let me know if there is anything else you are wondering about.
