Unable to listen in stereo, is that a software issue or defective unit. Very disappointing.
Xperia X F5121
Android 7.1.1
34.3.A.0.217
Hi @webcar2001,
I'll look into this for you and I'll let you know as soon as I have any information about it.
@webcar2001 The reason for this behaviour is because the FM radio has been changed with Android™ 6.0 (Marshmallow) and Android™ 7.0 (Nougat). The result of the change is that the FM radio is now allowed to automatically select between mono and stereo audio output, depending on the signal-to-noise (SNR) of the incoming signal.
