Hello Sony Xperia X fellws, I have an issue with my phone recently.
Sometimes it charges perfectly while other times does not at all.
I am not sure if it is a battery problem ot the charger blug itself!
Please let me know what do you think the issue's resource, and what to do to fix it ? Also does my stuff are going to be lost while replacing one of those things ? ( do I have to make a new backup )
Thank you so much
Hi @Dano0on, welcome to the community. I am sorry to hear about this.
Have you tied with other USB cables? Different wall chargers?
I tried to change the charger and also checked that it is working on other devices.
Now my phone died can't charge from any charger!
=( Idk what to do !
Thank you for replying, do you know if this gonna lost me my data ?
You will have to check if your local repair agents will keep the data, but in general, they will not.
Wow thank you so much for clarifying everything to me. I really appreciate your help.
Thank you all for your help and support you are the best.
