Hi. Only have the phone for a few months to find, maybe 4 times, that when I put it to charge over night and I turn it off, I wake up with my phone on and the green light on, even when the cable has been unplugged. Not so long I had the problem that it kept crashing so my phone has been restarted, rebooted maybe at least 3 times (bare in mind that it's less than 6 months old this phone) which now I dong have that problem but I've got this one.
Any suggestions?
Same with my x compact. Just done new software update and still no better.
As per solution reply this will be fixed in next update probably with Dec security patch (or Oreo update if released).
any update about this issued?
The ate came out this week. I've had it for 2 days. The issue is gone. The phone does not turn on while charging.remember the fix is in the December update not November update.
Same here. Problem solved by the December update.
А мне нравилась эта функция или глюк. Зато не проспишь и будильник сработает.
And I liked this feature or glitch. But you do not sleep and the alarm clock will work.
GT
