My wifi at work, not at home dont connect, at home no problem, but at work keep on saving even if i forget and enter again it save the password and dont connect. If i open a hotspot on my pc at work then it will connet.
Thanks any help?
Johan
@Dadjj Look that @uliwooly has a good point. WiFi Routers will fail pairing/authentication if the level of signal is very low. In order for you to be able to connect successfully you should try to get near the hotspot. Once authentication occurred you may leave the area of strong signal and it should remain connected.
Note: Mind that your phone will handover to mobile data from wifi every time the signal is too low to maintain active the connection.
