X Compact display is Pixelated
SOUNI1
Display is pixelated specially when i look at the screen from Angle... What is the cause of this issue????
20 REPLIES 20
SOUNI1
Camera blured images.. zoon on picture can you see it? Look at the Edge of screen.. IF u See Carefully and in a dark room i think you Can see it on your x compact too...
Emir1
Hero
I checked in the bathroom with the lights out and only the display of an X Compact illuminated, I made sure the background was bright with black text (Settings) with the highest available brightness and I was not able to find the image blurry. Just to make sure, I also asked a colleague for a second opinion on a different X Compact and we were both unable to see that it was blurry.
It may be that I don't quite understand what you mean, but as I mentioned in my previous post it would be best to have it examined if you are uncertain if your display works correctly. Slightly_frowning_Face
SOUNI1
Display is not blurry... It is pixlated i can see Horizental /vertical line pixel on display... I hope u can understand What i said..
SOUNI1
I had this problem on my old Z5 too... I Can't See Digitizer grid on X Compact display although but still it is pixelated... On Z5 OR Z3 plus digitizer grid is visible And it makes Screen pixelated when You Watching movie... It ruined the whole Experience With the Phone.. On X Compact display digitizer grid is not visible but still it is pixelated like XPERIA Z5 display...
SOUNI1
Hi Again @Emir let me Explain More.. When U look At "Xperia-X-Compact" display from Angle U See line like this on the Entire of display surface...
https://drive.google.com/file/d/0Byy3PUewHDFCMmhuQlRmaGY1QzQ/view?usp=drivesdk
Emir1
Hero
I found a different post regarding the display where a user had a similar question to yours, could you have a look here and let me know if one of these photos represents what you experience?
SOUNI1
I have similar Experience like The guys Who has Z5P... But in my Case Those lines is visible only When display is On.. As @alexdon Said that Should be Digitizer...
I don't have this issue with Apple OR Samsung OR Huawei Phones...
I think SONY Mobile Need Change...
Emir1
Hero
You are referring to these lines, right? During specific angles and lighting conditions I was able to see it on our X Compacts here as well, so I would say that it is normal for your device and there is likely nothing wrong with your display. However, I thank you for your feedback regarding this, I'll forward it internally on your behalf! Slightly_smiling_Face
SOUNI1
@Emir
Exactly... glad to see you found it Too.. Thanks FOR helping me...
Emir1
Hero
Any time! Sorry I was a bit slow to understand what you meant, I was so confused there for a while haha. Slightly_smiling_Face
