I have a problem which I cant seem to identify. It seems that the sd card may or may not be the problem, but it could be the complicated way the android systems works which I just dont understand.
It would be helpful if there was someone who could support when things dont work, in staead of a list of things in the manual to press. This is ok if things work first time but there are a few examples.
I downloaded a song to my phone, and when I try to play it, it says 'Cannot Play'...no explanation. If I knew why I may be able to solve it.
I have a 32Gb sd card which I used the built in Sony app to transfer on to. Sometimes this works, and sometimes it doesn't. Some of the pictures are blank, some are half pictures, while others are ok. Most of the music is ok, but a few wont play. Again no reason given. I created a playlist, which only appears when I hit 'Manage Playlists', but disappears again if I try and do anything with it. No explanation again.
I've tried looking in file manager, and although I transfered music onto the sd card, there are music files elsewhere....why in multiple places, and when the phone plays the music, where is it playing from?
I wish I could understand these questions, or find some kind of debug option to tell me what is going on with this phone...
Where did you download the song,
What format is it?
I don't know, but other songs from the same source play ok. More concerned with the lack of reason and information when things don't work
