Hello, I'm very disappointed with my new Sony Xperia X Compact with android 7.1.1 phone sounds/vibration management.
There is not a widget to select easily silence/vibration/sound as in my old Motorola Droid 4 phone.
And the (complicated) "do not disturb" funcion...reactivates the sound atomatically after the first phone call! Why?! (I don't find a function do modify it).
Also...I'm from Italy and I've italian language as default, so to write to you here I would change the phone language to English (I really don't know if the in english the funcion to silence the phone is called "do not disurb"...I suppose that because in the italian verision is called "Non disturbare") but the phone doesn't accept language changes!
Other thing: if I use the volume buttons to deactivate the sound, automatically the vibration remains on. There is no way to shut it off. Oh yes...the "Do not disturb" function....but as I told you it goes off after the first phone call!
I give you an example: I'm at a funeral or at an important ceremony and I don't want neither sound or vibration but I want to know who called me. If I activate the "do not disturb" funcion I have to reactivate it after every phone call gone lost? Absurd! Was so hard to add three buttons: sund, vibration, silence? And for silence I mean: silence without vibration.
You made thing too complicated!
