отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
GPS problem. XA2 ultra.
mondragon
Посетитель
I'm having a problem with my gps. the satellite can not locate my phone even when i'm outdoor. It's difficult to use any kind of navigation apps like waze or google maps, because it can not locate the exact location of my phone.
Anyone experienced this?
5 ОТВЕТ 5
Goli_cze
Посетитель
the same problem, it takes about 20 minuutes co get GPS signal (xperia xA2)...
Jr123
Посетитель
Same problem here
Atsic
Посетитель
I had same issue and this is how I managed to fix it......
You can try to purge assistance data. Open thet dialer and enter *#*#7378423#*#* (*#*#service#*#*) followed by pressing:
Service tests > GPS > Tap Purge assistance data.
Reboot your phone.
Sjg94
Посетитель
Yep same problem im in Australia an it says im by oxford in England strugglein 2 drive anywere a understatement
Alistairm
Посетитель
I'm having similar problems. When I open Google maps it usually know where my location is but loses GPS signal almost straight away.
