How to calibrate the battery
Серёга2
gt
1 REPLY 1
Jonas
Master
Hi @Серёга2,
You can calibrate the battery if you let it go really low, around 2-3%, open up the SIM/SD card slot and press and hold the OFF button until the device powers off. Charge it to full while the device is turned off and turn it on again after 3-4 hours.
I hope that helps! Slightly_smiling_Face
