My battery percentage drop 2% at once. Ie.: 75% -> 73%.
Someone with the same issue !??
Fw: .200
I bought my z5 premium 4 days ago ! and the battery seems really **bleep** ! the full charge drains in like 3 hours onscreen time ! the screen takes too much of the battery usage 40% ! on my last z3 it took like 3% ! what happened ! does sony lied about the battery life time ! i really paid alot in this phone and i dont see any advantage in battery ! i'm a very heavy user and i though that this phone will satisfy my needs( i tried the stamina mode but it doesn't work for me because i want to recieve notifcations from social apps while screen is off ) i need a fast solution or i will return the phone back ..
That's not quite accurate, I have a Z3 right next to a Z5 Premium, with that said the Z5 Premium has a 4K display when watching media.
can you just tell me how the the screen consumes 35% of battery usage ! and the battery drains from 100% in just 3 hours !!
Calm down, first things first, here are the forum guidelines
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
second, this is a user based forum
third, that's normal that the screen will use up more than 40% of the battery.
fourth, if you are watching videos, pictures (media) the screen will drain battery even faster because it will be on 4K, also check on other Xperias battery life and other brands battery life with the screen on while watching media.
i dont ! i just use whatsapp and facebook !
Battery is bad on premium. It always system 78% for the screen. Even I set it to the low. How to fix this???? The battery is not 2days more like 6hours.
