So what's everyone doing for a case?
Chippy_boy
Always been one of the downsides of not buying an iPhone or a Samsung has been the scarcity of case options - as opposed to the aforementioned where you fall over cases in every shop you walk into.
So what have you guys found and what are you going with?
14 REPLIES 14
xenite5
for the ones looking for a cheaper alternative I saw a Roxfit made for xperia clear case for £15 in carphone warehouse but it doesn't have a cover it is only back protection.
My previous case for xz premium was roxfit it was good but I also used a screen protector with it. I didn't see any screen protectors for Xperia 1 yet.
Lukalumen
Did they fix the Style Cover with the Xperia 1?
I had it with the XZ3 and it was a nightmare. Absolutely useless...
Now I got Sleo cases on Amazon and they're great. I got three in different colours and Sleo screen protectors. There was a few £ discount on Amazon if you buy more than one, so I really didn't spend a lot. The screen protectors are great, on the XZ3 they were really hard to find because of the curved screen
Daveydguk1
Just fitted the Style cover and it seems like a good case. Also bought a shocksock on amazon for added drop protection.
The phone on its own I found to be very slippery in your hands. I would advise any case is better than no case.
JanieD91
Yes I'm also happy with my style touch case,as I have been with all my previous Xperia. I did worry it would affect the sidesense on this phone,but if anything it makes it slightly easier to use.
