отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Adding and arranging panes
profile.country.FI.title
Team_0
Исследователь
Is there a way to add a pane (screen) in between existing panes? I can add one to the very end but then cannot rearrange the panes.
3 ОТВЕТ 3
Piscie
Whats is your device model number? And have you tried to touch and hold any item that you want to add to the new pane?
profile.country.NL.title
Strampke
Just add a new pane and slide the icons from one pane to the other.
Lord_viridis
To add a new pane, long press an icon and drag it over to the right, this will create a new app pane.
