firmware updates
davy-boy
firmware updates
can anyone tell me if there is a firmware update for the sony Alpha a500
3 REPLIES 3
StartTheCar
Hey davy-boy, welcome to the Sony forum.
There is no firmware updates currently available for this model.  If and when one is required it would usually be made available here
Out of curiosity, is there an issue with your Alpha that prompted your post?
L
photoclubalpha
Sony Europe released the v3 update for NEX-5 and NEX-5 this morning (5.30am) - however the link is not present on the site yet (11.00am) and what's showing is still the v2 update from July.
Here is the release as edited for photoclubalpha:
Sony has released the firmware upgrades which were promised at  photokina for the NEX models NEX-5 and NEX-3, and the Alpha mount lens  adaptor LE-EA1.
Readers in Europe can download the firmware upgrade  from:
http://support.sony-europe.com/hub/hub.html
Autofocus is now supported when using the NEX-5/NEX-3 with 14 lenses  from the full range of A-mount optics by Sony and Carl Zeiss that  includes telephotos, primes and zooms. Aperture settings can be  maintained during HD movie recording, and system menu operation has been  streamlined alongside other usability improvements. Registered  NEX-5/NEX-3 owners will be advised of the free update via email.
Autofocus with A-mount lenses
Single-shot autofocus is supported with 14 optional A-mount SAM and SSM  lens models3 when used with the optional LA-EA1 Mount Adaptor.  Single-shot AF is also possible while in movie recording mode by  pressing the shutter button halfway down. Support for AF operation with  A-mount lenses also requires a separate firmware upgrade for the LA-EA1.
Aperture priority with video recording
HD video can be shot while maintaining constant aperture, either in A  (aperture priority) mode or in iAuto mode with background defocus  activated. This aids the simple creation of beautiful background defocus  effects during movie recording.
Soft key settings
It’s possible to customise functions of two of the three soft keys on  the camera’s rear panel. Functions that can be assigned include Shooting  Mode, Shooting Tips, Precision Digital Zoom, ISO, White Balance,  Metering Mode, Flash Compensation, DRO, Auto HDR, Creative Style, MF  Assist and AF Area.
Menu start
When ‘Menu’ is selected, there’s now the option to display either the  main menu screen or the last parameter set. This simplifies quick  readjustment of recently-selected functions and settings.
MF Assist
An enlarged image portion can be displayed on screen with  user-selectable duration while in MF (Manual Focus) Assist mode. MF  Assist operation has also been improved. The previously-chosen magnified  image portion can now be maintained when MF Assist is re-selected,  making repeated checks of fine focus quicker and more convenient.
System requirements
PC: Windows XP SP3 (64-bit and Starter editions not supported);  Windows Vista SP2 (Starter edition not supported); Windows 7
Macintosh: OS X Ver.10.5 or later
All platforms: Hard disk space: min. 200MB / RAM: min. 512MB.
Upgrade requires USB cable connection between computer and NEX-5/NEX-3.
Autofocus function is supported with these A-mount lenses:
SAM lenses
• DT 18-55mm F3.5-5.6 SAM [SAL1855]
• 28-75mm F2.8 SAM [SAL2875],
• DT 55-200mm F4-5.6 SAM [SAL55200-2]
• DT 30mm F2.8 Macro SAM [SAL30M28]
• DT 35mm F1.8 SAM [SAL35F18]
• DT 50mm F1.8 SAM [SAL50F18]
• 85mm F2.8 SAM [SAL85F28]
SSM lenses
• Vario-Sonnar T* 16-35mm F2.8 ZA SSM [SAL1635Z]
• Vario-Sonnar T* 24-70mm F2.8 ZA SSM [SAL2470Z]
• Distagon T* 24mm F2 ZA SSM [SAL24F20Z]
• 70-200mm F2.8 G [SAL70200G]
• 70-300mm F4.5-5.6 G SSM [SAL70300G]
• 70-400mm F4-5.6 G SSM [SAL70400G]
• 300mm F2.8 G [SAL300F28G]
AF support also requires firmware upgrade for optional LA-EA1 Lens  Mount Adaptor.
With an A-mount lens attached to NEX-5/NEX-3, autofocus takes  approximately 2 to 7 seconds based on Sony measurement standards. Actual  AF time with A-mount lens may vary depending on the subject and  shooting conditions.
profile.country.fr_FR.title
kalalex
Hello,
When firmware for Windows 7 64 bits ?
Many thanks.
Alex
