Looking for software
Bob0151
For some time I have been using Picture motion browser and other software on the installation disc for my A200 on my old winXP computer. I've now tried to install it on a new windows 8 computer but it will not accept the disc.
Is there any updated software and where/how can I get it?
Blencogo
Hi Bob0151 and welcome.
The available downloadable software for your A200 can be found on the Support Pages here: -
http://www.sony.co.uk/support/en/product/DSLR-A200/updates
For Windows 8, you will need to use the upgraded PMB program "PlayMemories Home".
:wink:
3 REPLIES 3
Blencogo
:wink:
Bob0151
Hi Blencogo. Thanks very much for the help.
I've got Image data converter plus Lightbox nicely installed but have had to put Play Memories Home on hold for now as I don't have a USB connecter which fits the camera (never yet needed to use one)
Still, it is the Image data converter which interests me most as I've other progs. which fulfil similar functions to PMH.
Thanks again, Cheers.
profile.country.de_DE.title
cmosse
you can download the latest version of the Image Data Converter here:
http://support.d-imaging.sony.co.jp/imsoft/Win/idc/us.html
