nex 5 25 frame ps setup in video mode
rashid8998
guy how do i set up the nex 5 to shoot video in 25 frames per sec:smileywink:
please help
profile.country.de_DE.title
cmosse
actually the frame rate of the camera in 50i mode is 25p (sensor read out). The 25p signal is split into 50 fields (so called progressive segmented frame method).
Depending on your video editing software you can therefore set the project properties to 25p
2 REPLIES 2
cmosse
rashid8998
cmosse ur a star mate
thx for reply:smileywink:
