nex 5r - video advice needed.
greenwall123
I was out in the snow videoing my children sledging down a very white hill...I've just uploaded the pics to iphoto, but have horizontal break up as the kids move against the snow. Is this an issue with the camera, the transfer to iphoto or just the camera struggling with moving colour against a stark white background? When the children are still-ish, the image is fine...
many thanks
Paul
1 REPLY 1
blaireau_photo
Hi Paul :slight_smile:
If you have an example from this set of images that you are happy to upload onto this forum, please attach it to your next message in this thread so that I can take a look. If you are able to attach your camera to a TV screen or put the memory card into a regular USB card reader, you will be able to check if it is an iPhoto issue.
Thanks,
Simon
