help. i have a hdr fx1000 and a DCR VX2000 camera and neither one is being read by adobe premiere cs5.5 i am using win 7. yes i have changed the firewire to legacy. i also tried my hvr m15au hd deck . same thing no read.what could the problem be. premeire? win7 , sony? or?
How exactly are you doing it? What I usually do is I turn on my VX2000 first, then connect it to your computer. Then load the Adobe Premier software. It should work by doing this steps.
Hello elyahshuv - Welcome to the Sony Forums
To concur with what nimbystripes has said, this is usually the sequence that I use to get Firewire cameras to be recognised by my PC so hopefully this will also be successful for you.
Thanks,
Simon
