Sony A350
conncornet
Sony A350
How do you check the shutter count?:smileyconfused:
blaireau_photo
Hello conncornet - Welcome to the Sony Forums :slight_smile:
With the Sony A350, there is unfortunately no official shutter count function. However, one method that may work is to check the file number given to each image - although there are a number of factors that will make this inaccurate. For example, if the camera settings have been reset, this would have returned the file counter to zero.
Thanks,
Simon
1 REPLY 1
blaireau_photo
Thanks,
Simon
