Hi I,ve just bought a Sony A65 slt online should there be a manufacturers warranty in box?
Hello beboyle14
I am unsure if Sony continue to place a small warranty card in every single box, but in any case the warranty is automatic (you can double check with the original store if you have any concerns). You can register the camera for general support features by visiting the following link:
https://www.sony.co.uk/mysony/RegisterProduct.action?site=odw_en_GB
There is also an online version of a standard warranty card with the usual terms and conditions, and that can be viewed here:
http://www.sony.co.uk/support/en/warranty/general
Thanks,
Simon
Hello beboyle14
Thanks,
Simon
Hi,thanks for your reply about a 65,just used for first time today,dust spots on images on pc bit of a letdown thanks again
