Sony A7 bottom left-hand corner green/orange
ANMsad
DSC00272_1.jpgHi,
I'm having a problem with my new Sony A7. The camera is less than a month old and there is a problem in the bottom left hand corner of the image.
Depending on the photo it is an small area that is either green/orange, and almost looks like a sensor readout error. This problem is not apparent in anyother corner of the image and appears regardless of lense or aperature. It is also visible in JPEGs and RAW files (Capture One and Lightroom)
Any ideas of what this could be? Do I have a sensor problem?
1 REPLY 1
jumpsuit
Hi @ANMsad :slight_smile:
Thanks for posting the photos.
Have you tried a reset on the camera?
(Although I suspect this wouldn't rectify a hardware problem)
