Two A7R2, one very slow write and review
fazeppi
I have two sony A7RII, and very evident that the last purchased, the time to write and read the memory card is much slower than in the first A7RII. at first I blamed the SD card, not fast, then putting the same card, the second A7R2II and always much slower, try with other equal card, reset same story. Any suggestions?
Tags (1)
1 REPLY 1
JohntheMakem
Have you got them using the same firmware and on the same RAW settings? My A7RII was swift until I updated the firmware and switched to uncompressed RAW. Don't get me wrong, I'm happy I'm using uncompressed but now my camera writes to the cards at a snails pace and I have some of the fastest cards you can get.
