Hi Im wanting to know if my current hvl-f36am can be used to fire the hvl-f60m (before I purchase it) and still use the HSS and TTL functionality. I was looking into buying battery pack and light head systems for shooting on location to overpower the sun, but I think with the power of this strobe mixed with high speed sync I will be able to do everything I need in a much lighter and more portable package. Hope this is achievable?
Thanks
Hello UKstu99 - Welcome to the Sony Forums
I am currently looking into this to see how the two HVL units interact with each other. I will get back to you as soon as I am able.
Thanks,
Simon
Hi Simon, thanks for the welcome and looking into this for me.
The HVL-F60M is capable of triggering the HVL-F36AM but not vice versa.
HSS is available in wireless flash mode.
Best Regards
Michael
Thanks for the reply Michael...That seems strange....why would you want to use the 60 as a commander to fire a 36? So what is going to be my cheapest option for firing the 60 at the greatest distance in sunlight?
Is there an IR transmitter I can use on camera to trigger the hvl-f60m and still have the ability to use HSS and TTL?
Thanks
You will have to use 3rd party solutions like this one but I can not guarantee if they are fully compatible.
Check with the manufacture.
Sample of a 3rd party trigger:
http://www.pixelhk.com/Proshow.aspx?id=64
Using this kind of trigger (+ adapter if required) would allow to use flash in greater distance compared to Sony´s wireless control system
