2015 Bravia Android TV Issues
NickCo1979
Mitglied
6.373 ANTWORTEN 6.373
alellio01
Mitglied
Re Update.
Tv starts quicker than before, but 15 to 20second delay before soundbar starts up, But soundbar is working now. :slight_smile:
One thing i have noticed, do a full reset after update, its like the tv stores infomation about items connected to it, (like sounbars) and in my case, the sound only started to work correctly after i did the reset, but in all testing since, it has not failed to start, as it did before. \\\\\finger crossed.
XXX Porn still not fixed. This supprises me as i think this should have been marked urgent. 😞
Still playing around.
NickCo1979
Mitglied
Doubt the porn channel change will be made. It was raised on a thread in April 2014 https://community.sony.co.uk/t5/televisions/default-channels-when-using-the-tv-radio-switch-button-o...
Still not fixed after more than 1 year.
tennysonman
Mitglied
To change the behaviour of landing on an Adult channel with the TV/Radio button. Press the button until the Adult channel appears then change channels to a more desirable channel.  Then when the TV/Radio button is pressed instead of the Adult channel, it will go to the one you have selected.
NickCo1979
Mitglied
Nope, just tried and it always reverts back to channel 183, Adult XXX. People walking past my house when I tried it seemed surprised I was watching porn at this time in the morning.
alellio01
Mitglied
@NickCo1979 Good excuse. :grin:
jevande4476
Entdecker
I have the same issue with my 65X8505C and the touch remote. I did a reset of the tv and then the remote stop working. I saw the reset tip for the remote control itself i will try . When I contact SONY they send me the documentation on how to pair the remote. But that's not the problem I know how to pair it, it's just doesn't work. A bit disappointed :s
profile.country.nl_NL.title
tcviper
Entdecker
Sony, could you please fix the 5.1 issues and HDMI Sync? We have asked this over and over and still no update on this.
Also, can we please enable to let the forums here stay us signed in? Its annoying as what to have to login over and over everytime you come back here.
NickCo1979
Mitglied
Came in tonight, loaded up Amazon Instant, rented a film. Playback with no picture and massively stuttering sound. About 1 minute to play 6 seconds. Abandonded the Tv and now playing it through my PS4.
Annoyed.
andrewsoong
Mitglied
Anyone having issues with the Android app? I constantly get a message saying remote connected/ remote disconnected all the time. This morning at 6am the TV turned itself on to pair itself with the app.
Pretty much given up with the TV now. So frustrating.
And still none of the apps can output 5.1?!
psp888
Mitglied
i managed to get 5.1 out of the videos app, connected via optical out on the TV
