the changelog is interesting...
Adds support for internet browser - new functionality
Adds support for play memories online - new functionality
Adds support for Playstation Now - new functionality
Improves Wifi Connection - fixes
I guess I'm left to think that there's no stability of performance updates despite the pleadings on here.
Feedback for Sony - if you've improved the performance or stability it's worth stating that.
If you've not improved the performance or stability, I, personally, don't care about any of the features above. Please fix the performance and stability of the TV before adding extra things to go wrong.
Ta.
With the latest update menus are more responsive. Amazon video streaming is also much better, no more stuttering Just hoping it doesnt restart anymore. Also hoping the sound doesnt keep cutting out like before.
Hi all,
Downloading my update now so hopefully will see the same improvements as you all 😉
@NickCo1979 you think the TV would be more responsive and 5.1 working without any improvements?
Don't get stuck on the details of the support website and enjoy as per my message (not that clueless after all) the stability improvements.
I now checking when the next update is planned. My gut feeling says it might be mid/August or something.
So keep the feedback coming in the meantime so we can make sure our engineers have a total view & I will do the same from my side and keep you informed when more info is available.
Nico
Hi Nico, please could I have a link to the support website that has the changelog on it! Just so I have a bookmark I can go to and check every now and then myself.
There is def some improvements to the UI, aswell as added fetures like PS now, although PS now isnt fully working. But I dont want to get hung up on the apps as such, more the notion of weather or not the hardware is working as it should.
Thanks
