This morning when I turned on my KDL43W755C I was greeted with a flashing red light, it would blink 6 times pause then blink 6 times and so on. The joke tv would then turn on when the power/standby button was pressed on the remote. Upon start up the android logo appeared suggesting that the system has rebooted. This is the 2nd time this has happened, the first about 1 month ago. The tv has a hdd attached and the joke tv seems to be working ok! (as well as these joke tv's work anyway). Has anyone else experienced this or have any information? Thanks.
New update for Ireland:
Improves sound quality issues: v3.169
Firmware 28-12-2015
http://www.sony.ie/support/en/product/KD-55X8505C#SoftwareAndDownloads
p.s Please can the forum moderator tell me why my reply to RiscOn was removed?
ELRAOUK if the message is in the bottom left hand corner it is just randomly telling you the screen format and is harmless but just a little annoying.
I use sky also and am having very few problems with my KD49X8305 compared to others here.
I did have the above problem though and cured it by going into:- Settings, External inputs, Bravia sync and then set the options you dont need or use to OFF, that cured it for me but I cant remember which setting it was but there arent that many.
Incidentally I did also have a problem with my TV turning itself ON randomly even though both of the timers were set to OFF, it also cured that.
As a precaution I have also turned of YouView as I dont need it and figure its one more potential problem area removed.
I've just had a full refund from currys based on the tv being misold as there is no HD recording. Quote SOG act. Tv is 4 months old.
@mk1.golf.1983 I had exactly this once, and was informed that it indicates a hardware issue, but may recover if powered down. The online manual states....
If the illumination LED flashes red, reset the TV
by disconnecting the mains lead for two
minutes, then turn on the TV.
If the problem persists, contact your dealer or
Sony service centre with the number of times
the Illumination LED flashes red (interval time is
three seconds). Disconnect the mains lead, and
inform your dealer or Sony service centre.
Mine has not done it since the power reset.
Do Sony publish full change lists of these updates? They only ever seen to announce a couple of fixes when surely there must be more included. The version numbers often jump significantly.
Also how come UK seem to be in a different timeline for updates now. Do Sony have to go through some sort of Youview approval process now that has been added to the UK one?
@micowan20 wrote:I've just had a full refund from currys based on the tv being misold as there is no HD recording. Quote SOG act. Tv is 4 months old.
Well done If only more would do this then Sony may sit up and take notice. Seriously folks, while you are all willing to accept this rubbish from Sony they will keep on stringing you all along 😞
Think I've seen a couple of people mention this but last night I started getting the Screen Format: Full message popping up while watching sky and then today I can't restart by holding the power button on the remote for 10 seconds. The pictures keeps going jerky too while watching sky (which I was trying to restart). I imagine it will be fine after I pull the plug but really strange that a few people have had the exact same thing happen at the same time when it's the first time it's occurred. I've had the most recent update since it came out too so nothing to do with just applying that.
Yes.
@frogger38, I phoned Sony support today and the guy I was chatting with talked me through various steps to perform, firstly was to get the serial number and software version, then he wanted me to turn off remote start (which coincidentally I turned on last night) I stated that I use remote start as I also use tv controller app, so that was left turned on. The next step he wanted me to carry out was to turn off automatic time and date? I just did it. I asked the guy what the fault code related to and his answer was that the panel was faulty but as it was working it couldn't be? Quality...
