2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
profile.country.RO.title
alexw85
No problems with the sound on HDMI. Just the digital tv with 720p/50hz and google play store not showing apps or server error.
Alex
alexw85
V 3.155 forgot to mention
alinux33
Thank you Alex, that's good news, but I think a factory reset will be your fix, Android its not the most reliable OS for a smart device and Sony didn't troubled to optimize it.
How about brightness variations when you watch movies from external source or OSD menu shows up?
Many thanks for quick reply! Enjoy your new TV!
alexw85
I tried everything. Reset to factory settings. It's a bug somewhere. For brightness variations you have to switch off the last setting în brightness. I don't know the name now Alex
pajo100
Diseqc works fine but initially you have to set scan option to network or single scan to alter it then revert to full scan before searching which takes ages for 3 sats.
Also noticed a problem when trying to add new updates to channels lists it deletes all the current channels and only keeps the updated ones so you have to rescan all again!! Weird.
Tarzion
Managed to get the UHD channels working in 19.2 using a manual scan.
Tarzion
Can scan and view all the channels listed here
http://flysat.com/astra19-uhd.php
alinux33
@alexw85 I am not sure if that will be a good idea, but worths trying to side load Clean Master? Might find some junk stuff in android OS. I have noticed that Album app didn't worked for me at all.
Or in the Advanced settings, Apps, find the app that causes trouble and see if you have delete cache or data.
Also try enabling Developer options by clicking OK on remote 6-8 times on the build number.
frogger38
@Raichuu wrote:
I don't suppose anyone has the email address I should contact to get them to ask me for my contact number for a "discussion" about my 65X8507C?
 I've had the TV since launch, and firmware after firmware... Wait after wait, I'm totally exhausted.
purchased rom Sony.co.uk as well ;-(
Sent by PM as Forum deletes email addresses.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
Caledonian_TV
Not always...  I couldn't get mine to operate the switch at all; yet the same switch from the same lead plugged into another receiver worked perfectly.
