2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Thejak80
It seems even though I'm fairly new to the party here , that people are getting quite rightly so annoyed and frustrated with Sony's approach to tackling issues with these TVs I for one are getting quite annoyed at the fact of having stability then for a fundamental feature of the TV; WiFi to start dropping out every few minutes, kind of defeats the object of a smart TV
Sony needs to put out something to their customers acknowledging what's being fixed and allow people to submit bug reports not just say "contact support" at every opportunity.
I think the design and build of these sets is fantastic and reflective of Sony's eye for detail but the software just lets the User experience down and indeed the support that they offer
John1950Hitchin
@adyjay33Yes it will go in the loft but as a new TV costs money until I can afford a
new one I have to put up with this piece of junk...
Unless of course you want to give me the money? 🙂
Don't think so as I already have a great TV.
REALLY HAPPY CUSTOMER
profile.country.GR.title
MiCal1967
@frogger38 wrote:
@Anonymous Now that we can log in again...
Generally the system is stable since the April update.
I have ONE anoying issue out-standing which relates to the response of TV to the remote commands. Sometimes on click of a button it is interpreted as multiple clicks and at other times whilst navigating the menu or apps, sometimes the tv stops responding to remote clicks. if I then wait for 20 seconds or so it starts working again.
Me too
MiCal1967
@Kenneth_J wrote:
So i decided to keep my TV in hope things eventually will get fixed. Suddenly i'm having a new problem, when i turn off my TV the picture turns off but they sound stays on for 15-30 seconds..(maybe android is living it's own life inside my TV) o.0
If the annoying reloading of the TV guide and the youtube lag build-up isn't fixed by the time PlayStation VR is released i sure hell ain't getting them or the PS4k.
Me too. But sound remains active for about 5 seconds and not 15-30.
Started 3 days ago.
adyjay33
I get a massive delay in it starting up, sometimes over 50 seconds and then only after using the remote again to try and get it going never used to be this bads, god knows what its up too but whatever it is I expect it to not turn on at all soon as this delay is getting longer as time goes by.
Nothing in my opinion seems to have been fixed since I have had it, its just as rubbish as it was when I foolisly bought it and waited in the vain hope they Sony would sort it, the loft it where it will end up.
I will warn everyone I meet not to buy Sony again as they have let me and many other down and dont seem to be bothered about it, no wonder Sony is going down the pan along with many other Japanese makes as its their attitude towards customers that is the problem along with highstreet stores that cant be bothered too.
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
rooobb
@adyjay33 you still didn't follow the suggestion to factory reset your tv, still not returned your set and still complaining.....
7-Zark-7
Started 3 days ago.
My sound has always been active for a few seconds after I hit the power button to put the set in standby, just an annoying quirk of the set but not a big problem IMO.
hextablephil
For me really annoying as I have to then get off sofa and unplug tv....
have to put my beer down.
adyjay33
Rooobb, I have factory reset that TV many times especiually after a firmware update...I think I know the procedure off by heart....
As for taking it back, maybe you have not bothered to read my posts, but then again I doubt Sony do either.
Maybe you should check first before posting?
Oh and why am I not allowed to complain about this crap TV?
I have done everything they have asked apart from put a hammer through it, although sometimes I feel like it, to get this TV working as a TV should and it just wont, hey maybe you can come and pick it up for me and return it, I dont have the time. I sure as hell cant take time off for a Sony guy to look at it and say "Im gonna do a factory reset and it will be okay" well sadly it wont, I think people are just resigned to the fact that theses TV's are lemons and badly built with poor software. Hell if you want to pay for a new replacement TV for me you can have my one! 🙂
john.pringle
Why don't you just send it back like you advised lots of other members  instead of moaning about it. You have plenty of time to post  on here.
