2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Mission360
Nonsense
Skighpilot
I have been holding off buying a new TV because of these problems. I have now received the following email regarding firmware update:
"Dear Sony customer,
Having continued our engineering efforts on our new Android televisions since our most recent updates on our website, we can confirm that we have overcome the technical issues reported, and a new firmware version is now available for UK residents to download:
-          PKG2.605.0052EUA (for 2K models)
-          PKG2.605.0052EUB (for 4K models)
Please visit the link below to stay informed on all future firmware updates.
We thank you sincerely once again for your patience as we work to improve the Android TVs from Sony.
http://www.sony.co.uk/support/en/article/73499
Best Regards
Sony Support Team"
I wonder if anyone has installed either of these updates and, if so, what the result was.
Kevwoods12
That's what the last 10 pages have been all about!
gunit1978
Update installed and factory reset done, seems a lot better response wise, netflix 99% screen hasnt happened again yet but not had it on as much as been reinstalling kodi etc.
I have noticed I can only cast from my photo and video gallery now, and have lost the option to cast from FB, youtube and chrome etc
This is on a 43w805
Skighpilot
Thanks.
I have read them again but have not seen anything about the functionality of Android TV itself, other than screen casting and Netflix functionality.
Early versions of Android TV were apparently very poor and I wonder if that has improved. The model I am considering is KDL-50W805C.
dspencer999
Just discovered a new feature. 3D movies no longer play on Plex. Brilliant!
Abercrombie
Its still possible to do 3D with Plex. Go to the settings from the main android TV screen and enable 3D from there. I managed to do this several times after finding that it isn't available in the pop-down menu from within plex. It's a bit hit & miss, but does work
Sent from my iPhone
frogger38
@cozzykim wrote:
@andrewsoong
I don't think that the TV has the correct profile to act as BT sound source 😞
EDIT: That would be a superb candidate for a firmware upgrade, I use a tiny BT transmitter at the moment, when the wife has to go to bed early for work.
Good idea, but there might be a lipsync issue due to the latency of Bluetooth audio. I use BT headset when watching movies on the iPad and it is acceptable in that scenario, but wit a big screen, it might be more noticeable.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
mk1.golf.1983
So after being pretty pleased with the recent update I have now noticed that I am unable to Cast from youtube or soundcloud. I have restarted the tv numerous times, restarted my phone numerous times, set the time as network time on both devices and done an initial setup. Any idea's because if this doesn't work the tv is going back. KDL43W755C
rdlowry
Casting of YouTube and everything else is still working for me after the update. The Cast Receiver on my KDL43W755C updated to a new version after I did the upgrade. Version 1.1643955. I've got a Nexus 5 with Marshmallow installed.
