2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
EggDublin
Casting is not working for me on the KD55X8509C. Has anyone managed to find a fix for this on this set?
nickbaker66
For casting I use Allconnect from the play store
Hope that helps
EggDublin
Thanks @nickbaker66 looks like a good app but the problem is the TV itself, I can cast to other devices. I have found a thread dedicated to this issue so I'll post there too. It appears to be related to the Oct 13th firmware update.
https://community.sony.ie/t5/televisions/android-youtube-app-cast-icon-not-appearing/td-p/1886811/pa...
rdlowry
Did you check that the cast receiver app is at the same version I posted earlier? After I updated tv firmware there was a Cast Receiver update available in the Play Store on the TV. I'd imagine this would have automatically installed eventually, but it was listed in the updates tab after I did the update. Worth checking.
We just got this message from Sony Nordic:
"We just couple minutes ago recived the report from Sony that the Cast-function is not working after the update to latest FW.
We have also tested in our lab this now, and can confirm that cast-function is not working.
Sony is working on it, and at this moment we have no timeframe when it's solved."
Guess we'll have to wait ...
Brigante01
I've discovered a bug in the new firmware on KD43X8305C UK model. Probably affects all X830C models though.
As I'm using the TV exclusively as a PC monitor my use of it is a bit different.
When I set the TV to display 1080p@120hz from my Nvidia 980ti over HDMI I get artifacts across the screen. Looks like short white lines that flashes up on the screen.
It does not matter which colour format I set, 4:2:0, 4:2:2 or 4:4:4 produces the same results.
Others are reporting the same issue with various HDMI cables and graphic cards.
This was working fine before the 13th October firmware update which makes me think it's a software issue and not hardware limitation.
Maybe this is something Sony could have a look at for the next firmware?
dataghost
Much happier with the TV after the update, and appreciating the little speed improvements and additions here and there.  However the set has lagged and crashed on me at least 4 times whilst testing everything.
Then again, while we have Android as an OS I guess that will never truly go away.  Shame they couldnt have struck a deal with apple to use iOS (wishful thinking I know).
theshamelessmanc
What models are people having an issue with the Cast function? Only asking because I am able to cast fine. I'm not a 4K set owner, mine is a W805C. Is it possible this is only affecting particular Android TV's and not the whole range? Would be interesting to see a list of which ones it is and isn't, or if its a random bug!
t1mmm9879
w805c here and my set has been working with no issues.
I didnt really have any pre update and after the update things just seem snappier really.
The only bug I'm seeing is when switching to my PS4, there is a sound delay (all be it very small) which is resolved by navigating to the sound options and changing the sound setting then back. That seems to sort it... Not ideal but my only complaint.
I have a 55W809C at home where Cast doesnt work.. but the same model in our
store works flawless.
In our store, the 43W809C, 49X8309C, 55X8509C, 65S8505C, 65X9005C and
75X8505C doesnt work with Cast or Sideview. But many of the other models do
just fine (all running 5.1.1)
It really makes no sense at all?
