2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
darrenj11
This is not for X93 this thread is it?
jain236
@darrenj11 this is the place for any sony bravia android TV s**t:smileywink:
darrenj11
bu theres no mention of X93 in all this, so I assume that you are having problems with the other range of models?
darrenj11
X85 is all anyone mentioned...
adyjay33
If its a 2015 model Android TV, then I suspect that all the models produced in 2015 with Android are affected.
Whats the problem with your model and are the issues the same as other models mentioned on here?
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
jain236
i am here because of my X83. i have also seen few people complaining about higher end modes like yours
Teknixjack
My X93 has all the issues others are mentioning so I think all android 2015 Sony Bravia TVs are affected
adyjay33
This was sent to me on a PM as the poster could not get it to work.
Thanks to Publiclyavailable for the information.
In reply to my post about what was said to Currys PA replied below to me.
To answer your point, I just kept a log of dates and events and presented the store with them. I reminded them of the new Consumer Rights Act which only came into force in October 2015 and reminded them of Currys' own policy, as I quoted in my post.  NOTE their polcy mentions that the product defect mus thave occurred during the first 30 days, not that you have to report it during the first 30 days!  This is quite useful since the CRA has a reporting limit of 30 days. Currys' seems to have no time limit on actually reporting, just as long as the fault happened within 30 days.  Por policy wording on their part but helpful to the rest of us.
If you want a decent summary of the CRA check this out. http://www.which.co.uk/consumer-rights/regulation/​consumer-rights-act
I went in to the store on at least 5 occasions to talk to the sales team and formed a "working relationship" with them there. I agreed to keep the set but reserved the right to return it if it didn't improve.  I got them to check things out with the Currys' Customer Service hideout and then asked them if they'd be kind enough forward me the key points of the reply and to confirm in writing that they agreed that I had the right to return the set.  This then meant I then had the email address of the local store so I then had a direct line in to use regularly.
Feel free to post this in the forum because I can't get in to it at the moment.  Hope this is helpful.
mattstev
Now this could be the kiss of death but since having turned off youview I have not had any issues...
Now if they would just let me install the ITV and C4 players from the App store I would be happy.
The lack of response from Sony on twitter is amazing. Perhaps we need more people tweeting?
darrenj11
you presume, and thats why ive been following this thread. Yes the TV doesnt have HDD recording but I dont care, Yes its slow on Android but I hold out for updates, and yes the HD channels used to have voice sync issues but that has resolved since update.
The screen is stunning and the audio is great, so pending the sluggish Android TV, im overall very satisfied, and presume therefore that this does not impact X93 range.
