Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
how did you install aptoide ??? as it dosnt show in google play on my tv i add to download the .apk first then install it through ES explorer but it dosnt show on the home page
kind regards
fether
I installed mine the same as you through an apk via ES and it shows on the home page. It's not really worth it though as the only app Aptoide offers which I can't get on Google Play is showbox. The rest are the usual useless stuff.
I've got a call coming from sony UK office this week. I just hope it ends my nightmare.
@fether wrote:how did you install aptoide ??? as it dosnt show in google play on my tv i add to download the .apk first then install it through ES explorer but it dosnt show on the home page
kind regards
fether
You need to sideload Aptoide TV for that, not the regular Aptoide.apk.
cheers for that
regards
fether
hi all iv managed to change the Developer Options to "at most 3 processes" but when i reboot the tv at any time the settings revert back to the way they were at the begining.
is there any way to stop this ??? please
kind regards
Fether
I googled that a couple of weeks back and the answer is no. It's androids fault not Sony.
ok cheers thanx for the reply
