Bravia 65XR80 Lip Sync issue.
zoz1234
I recently replaced my Bravia XD93 with a Bravia XR80. Straight swap.
My Sky Q box is connected to the TV in the HDMI 1 input. It's not a 120hz input but the Sky Q box doesn't output 120hz, so that's fine. No lip sync issues with this set up.
My UBP-X800M2 4K blu ray player is connected to my TA-AN1000 amp in the BD/DVD input. The amp output is connected to the XR80 via the eARC input. There is a lip sync issue with this connection. I can't currently fathom out why. My HDMI cables are QED and capable spec. As far as I'm aware my gear is compatible. I haven't tried an optical cable, but at the end of the day the eARC with HDMI should work. When I adjust the settings on the amplifier to 130m/s, it looks better, but I don't like having to do that.
When I play a disc and turn the amp off and have pass through on, the lip sync is fine! It's only when I turn the amp on and output the sound through my 5.1 system.
I had no problems whatsoever with the XD93. Any thoughts from someone with more knowledge than me would be appreciated. It's a head scratcher.
19 REPLIES 19
daveyh64
Enthusiast
I wouldn’t say this is necessarily a problem with the TV but with the AV processor, so I might have posted this in the Home Cinema category, mainly because you are saying the lip sync issue is between the Blu Ray player and the amp.
Another thing why isn’t your Sky Q box connected to the amp rather than the TV.
Have you connected the Blu Ray player to the TV to see if there are any lip sync issues in that configuration.
If there are no lip/ sync issues with the devices connected directly to the TV then it is probably something in the settings of the amp.
First though I would check the settings on the Blu Ray player, i.e check that it is on passthrough and no lip sync settings have been input, so either Auto or off, if it has those settings.
Check that the TVs A/V sync setting is set to Auto.
Settings> Display & Sound> Audio output> A/V sync.
Here is a screen shot from the troubleshooting page of the online manual
for your amp.
zoz1234
The TV audio system settings are as such;
Audio system prioritisation - On
A/V Sync- Auto
Digital Audio Output - Auto
eARC setting - Auto
My amp's pass through setting is on.
The lip/sync option on the blu ray playback is set at zero.
I'd always connected the Sky Q box up straight to the TV on my XD93 because my wife doesn't use the amp at all. She's not into it, and prefers just a simple Sky to TV operation. I told her with the pass through it's not even a thing, but to avoid any hassle I just set it up that way.
Just for extra info, I do have a PS5 connected to the amp's game input. That has no problem with sound sync either.
The TV does have one spare HDMI input rated at 120hz, it's labelled as an input for the PS5 but I stuck to my old set up of putting the console through the amp. I could use that input for connecting the blu ray straight to the TV as you have suggested. I knew that was an option but I've been obstinately refraining from it so far because the way it's set up should work!
Nothing has been changed in the settings from when the XD93 was in place and running perfectly.
Now suddenly it's not with the XR80 in place. I agree with you that it's probably a setting on the amp somehow that's just not gelling with the XR80. But I can't find what. Which is strange because they're both the newest pieces of kit in the set up. Both Sony.
daveyh64
Enthusiast
Have you set the amp up as a Bravia sync device in the TVs settings.
And Enabled it under the Bravia Sync device list setting.
Settings> Channels & Inputs> Bravia Sync Settings
And just to check have set your HDMI Inputs on the TV to Enhanced format.
Another thing you could try in the TV settings menu is to
go to Settings> Channels & Input> External Inputs> External device setup.
You may have done this for the older TV when you first hooked it up to the amp.
I would press the Set up button again and press Next.
When the screen asks you if you can hear the audio select No.
Then click on Exit.
Now go back and click on Set up again. Click on Next.
The screen should now show a progress bar as the TV and amp communicate with each other, once complete click Done, then Finish.
This may just reconfigure things and help clear the problem as the amp knows which TV it is now outputting to.
I only mentioned temporarily hooking up the Blu Ray player direct to the TV to see if there was a lip sync issue with using the TVs speakers, and if there was not switch the amp on and see if the lip sync issue is still present in that configuration.
Or have you tried switching the HDMI input the Blu Ray is connected to on the amp just in case to see if lip sync is a problem on another HDMI input.
It is interesting you are not having sync issues with the PS5 and only the Blu Ray, which would point to a setting on the Blu Ray but you haven’t changed any settings on that from when you had the old TV in the mix.
Can’t think of anything else to try at the moment if I do I will get back to you.
zoz1234
I'll try all the suggestions you have made some time today. I just wanted to thank you for your time spent already helping me get to the bottom of it. The differences between the two TV's is the new one is 120hz and eARC as opposed to 60hz and ARC, but I didn't think that would cause any problems with my X800M2 or TA-AN1000. That's why I was blaming the TV. The TV is the only thing that's changed. I tried the most obvious thing initially and bought a new HDMI between the blu ray and the amp. It was QED but they are old now. As soon as I removed it I knew it was going to be that because it was a performance with ethernet range. I put the new QED one in anyway and the problem remained. I'll take a picture of the HDMI configurations today from the amp and post them here to you. I have a sneaky suspicion like you, that that's where the problem is. Or I'm hoping so. Something simple in the set up menu. What I've always done is put the HDMI connections on max setting, because I have the equipment to handle it. These pieces of kit are supposed to mesh together. Or at least that's what I've presumed.
zoz1234
The HDMI lead "wasn't" the issue is what I meant. 👍🏻
zoz1234
Just noticed something, maybe you could give me your thoughts on it. I'll attach the pictures of the HDMI settings. Blue background is the TV menu system, black background is the amp menu system.
 The TV supports only two 120hz rated inputs. HDMI 3 eARC and HDMI 4. This is referred to as the HDMI input if you have a PS5, but as I have previously just used the game input on the amp I just stuck to that.
So, I've activated the HDMI inputs on the TV on the maximum settings. Enhanced for 1 and 2. Enhanced advanced for 3 (eARC) and 4. (PS5)
Looking now at the settings available on the amp HDMI inputs, the amp only has enhanced as available for the BD/DVD port? Game and media box are both advanced 4K 120hz. Are you not supposed to play 4K blu ray on a 120hz setting?
The available amp settings are suggesting that I plug the BD/DVD into the amp which is only an enhanced input then into the eARC. But the eARC then should be downgraded to only enhanced to match the amp output for that piece of equipment. That would mean connecting the PS5 straight to the TV like the TV manual was suggesting.
What are your thoughts on this? An eARC setting of enhanced advanced on the TV but only advanced for the amp input for the blu ray. Should this be causing the lip syncing problem?
zoz1234
I tried the set up again, clicked no when the sample sound was playing. When I went back into set up, there was no progress bar to show communication between the amp and the TV. The sample sound just immediately started playing again.
zoz1234
Right....things I've just tried. I reduced the eARC to enhanced, to match just the enhanced input for BD/DVD on the amp. Didn't work. Switched it back.
I plugged the HDMI for the blu ray into the media box input. That's rated as 4K 120 like the gaming input. Still lip syncing delay with the picture.
So next I fed the blu ray straight into the TV. HDMI slot number 4 which is a 4K 120hz input designed for a PS5. No lip syncing issues. This works.
But why? The system is designed so everything feeds into the amp and you send the feed to the TV eARC in from the eARC out of the amp. It's working fine for the PS5. Why not the blu ray? I've got a workaround now, but that's not the point. One thing I don't know, is the quality diminished in anyway? Or is what I'm getting on the screen and hearing from the speakers exactly as it should be if I'd fed the blu ray through the amp?
daveyh64
Enthusiast
When you connected the blu ray player directly to the TV did you play sound through the TVs speakers
and then through the amp to your hi fi speakers. If so were there no issues with lip sync in both cases.
Is your blu ray player capable of 120 output, look up the specs for it. I think it may only be 60
On the TVs HDMI signal settings page for HDMI 3 (eARC/ ARC) keep it on Enhanced Advanced but switch off
VRR (Variable Refresh Rate). Restart the TV.
Now try the blu ray player connected to the amp and see if that has improved matters.
This is just an experiment to see if VRR being on is affecting the synchronisation of audio and video from the blu ray only.
At the same time try the PS5 connected to the amp with VRR on the HDMI settings for the PS5 to amp connection but off on the TV and see if its A/V sync is still okay.
