How to hard reset KDL-43W805C to factory/default settings
Cyberlife
hi
how to hard reset KDL-43W805C to factory/default settings
2 REPLIES 2
Anonymous
Not applicable
si-mungo
The above link appears to be broken. But I found the instructions here https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kdl-43w809c/artic...
Tags (1)
