Sound bar switches to TV speakers and say communication failure
i have connected my new Sony Bravia to a Sony soundbar using HDMI into earc.  Originally switched on with TV. now doesn’t and when I switch soundbar on it says audio connected and the quickly switched to Tv speakers due to communication failure.
2 REPLIES 2
If I remove HDMI cable from sound bar and connect via Bluetooth it works
royabrown2
Hero
@PaulofLutonAC
Are both TV and soundbar eARC enabled?
Is the HDMI cable in use for this an ‘HDMI with Ethernet cable’?
Do you have a setting on the TV to choose between ARC and eARC?
Does the cable from the soundbar go to the eARC HDMI input on the TV?
