Hi everyone. I've got a Sony KD49X8309CBU and for some reason I can't pick up any digital signal through the antenna so I can't set up the you view. The signal through the dish is fine. I've tried the antenna in another TV and that definitely works. Is there something I can try?
Hi there
In order to help you, i think we need to take a step back and go back to basics first.
Hi there
You must use the DVB-T2 tuner on the TV and pickup a 'freeview' signal.
@Aj1soad wrote:Hi everyone. I've got a Sony KD49X8309CBU and for some reason I can't pick up any digital signal through the antenna so I can't set up the you view. The signal through the dish is fine. I've tried the antenna in another TV and that definitely works. Is there something I can try?
Hi
Be aware that activating YouView will delete all your satellite tunings - you have to choose which of the two you want.
But broadcast Freeview coexists with satellite, so try ignoring YouView, and doing the Freeview tune-in that Quinnicus suggests.
thanks for the reply. ITV player and 5ondemand wont work without the Youview though. ive tried disconnecting the dvb2 cables and conected a normal antenna to the antenna port and its not picking anything up. do i have to delete the channel list on satelite first or should it do an auto wipe when doing the antenna scan?
@Aj1soad wrote:thanks for the reply. ITV player and 5ondemand wont work without the Youview though. ive tried disconnecting the dvb2 cables and conected a normal antenna to the antenna port and its not picking anything up. do i have to delete the channel list on satelite first or should it do an auto wipe when doing the antenna scan?
Demand5 is available outside YouView - it's All4 that isn't, along with the ITV Hub.
And just retune - no need to delete existing tunings first.
Sorry did mean 4od. But I'm still not picking any signal from the Antenna scan. Any idea?
Hi there
Got it sorted out now. Ended up having to do a factory reset and it picked up the signal then. Thanks. for the help
