My KD65A1 is just 4 months old, recently it has been TURNING ON randomly...please help
You could also try disabling Remote Start in the menu and see if this works?
Did your suggestion but unfortunately, it turned on again after just over an hour...please advise.
Thanks, so far no similar problem occurred the past 24 hours...
Glad to hear it!
Just got home from work, been away from 8 this morning, the tv was on again, for how long??? I can’t tell but the tv screen is warm to touch...and I thought the problem has been solved...any advise would be highly appreciated
