KD65XG8096BU not connecting to any bluetooth devices
Shahul_G
HI All,
I just bought  KD65XG8096BU android tv and was trying to connect to my sony headphones and sony bluetooth speakers, but my tv is not connecting to any of these... the irony is that all 3 devices (tv, headphones, speakers) are all sony, still not detecting at all. Did software update, did restart the tv, did factory reset, did switch off and on the  bluetooth, had charged my devices full and tried, nothing worked. Can anyone help or suggest?
Regards,
Shahul
1 REPLY 1
Marino.Manolo
This model can't connect to Bluetooth Audio devices because there is not the A2DP Bluetooth Profile...
A workaround is: download via PC Browser and transfer into TV via USB Memory the App called Bluetooth Pair, so, install the App by a File Manager (downloaded from Play Store) and after that try the Pairing...
