Quality screen protector
guitarman60
I was skepical but bought a 55" version from the USA is Amazon.  Have to say the image is as sharp and clear as ever, and our new kitten can't hurt my tv screen either.
They aren't cheap at £119, but are easily fitted and I recommend them.
Jeffrey Cooper
guitarman60
They make them in large sizes. Super quality acrylic with decent fixing kit. I got mine from: 55 inch Vizomax TV Screen Protector for LCD, LED or Plasma HDTV https://www.amazon.co.uk/dp/B00U13MS10/ref=cm_sw_r_cp_api_uS-tzbR6F0T9V
Jeffrey Cooper
5 REPLIES 5
Anonymous
Not applicable
Hiya
Im curious - what screen protector?  Didnt know they made them for TVs
guitarman60
Jeffrey Cooper
Anonymous
Not applicable
Ahhh gotcha now.  I see how it works.  I was thinking it was a large version of the mobile phone or Tablet protectors, where it just sticks to the TV.  But yes, saves TV screen from pets and small children too.
guitarman60
It's as good as, if not better than an adhesive version.  Superb picture and no dark corners etc.
Jeffrey Cooper
Courts123
I got myself a screen protector too! I got mine from The Screen Protector thescreenprotector.com
Can't believe how good this product is, I can't even see it on my TV! Definelty worth a buy if your as clusmy as me or have children who throw things at your TV. My Wii remote slipped out of my hand whilst I was on the Wii but fortunetly I had the TV screen protector on and my TV stayed intact!
As well as that, The customer service at The Screen Protector is so kind! So I definetly reccomend them, and their prices are really good! Way cheaper than £119 :thumbsup:
