Reboot Loop
Spri2005
Reboot Loop
My KD-49X8005C TV had an issue with Netflix where it had lines across the screen, it was only for Netflix. I tried reinstalling Netflix and that didn't work. I then factory data reset the TV and it is now stuck in a boot loop. I have attempted a forced factory reset aswell, still stuck in boot loop. Any advice on what else I could do?
Tags (1)
2 REPLIES 2
rooobb
I think is the main board gone unfortunately
Anonymous
Not applicable
Hi there,
Yea sadly it seems that right now the TV needs to be repaired. So I would recommend getting in touch with Sony if you want the TV to be repaired.
Cheers.
