When I change channel, horizontal stripes appears for a couple of seconds. This only occurs when I change channel.
I have an Android tv-box connected to my tv.
Is there a way to get rid of these horizontal stripes ?
Does it still happen if, as a test, you disconnect the Android box?
I don't have any other picture source and it only happens when I change channel on the Android box.
I suspect that it is a screen refresh issue. The screen is only 60 HZ
Stupid me, then, for blithely assuming this was when you change channel on the TV 😢
I think you need to try this Android box on some other makes and models of TV, and see if you get the horizontal stripes on them, before you can report this as a Sony problem rather than an Android box problem.
