Hi, I have a Sony BRAVIA KD43XD8305BU which i use my PS4 Pro on - When going into the HDR settings on the console, it only shows as supporting 2K HDR - With 4K HDR not supported? Is there a setting on the TV which changes this to 4K HDR? The TV Supports full 4K.
you need to set the HDMI input to "enhanced mode" in the settings menu.
Everything should be fine after doing so.
Peter
Hi Peter,
Thank you for your comment. Will do that and get back to you if it works.
Kind Regards
Afzal Hussain
I noticed it was because of the HDMI Port it was in.The settings were already on "enhanced mode" however HDMI 4 only supports upto 1080p and had to be switched to HDMI 1-3 which i did and it started to display 4K gaming content.
Kind Regards
Afzal Hussain
We have the Sony sound bar too, HT-NT5. So the PS4 pro goes into the soundbar and then HDMI 4/ARC port.. Which is the only Port soundbar works with. Not too pleased with their set-up considering the amount of $$ spent.
