Sony Bravia KD43XF8096BU not working :-(
nesouda
24th December TV remote became unresponsive would not work, did the remote fix thing still no joy, thought I would try unplugging and plugging it back in so that the TV would reboot,  wrong move all I had was a black screen nothing, no standby light, after much checking of power lead plugging in in an out of different sockets it eventually rebooted and all was well, picture back and remote working as normal.  Till the next morning the standby light was out again and the TV not powering up, found a neighbour with the same set tried his power lead still no power.
Probably going to have to contact Sony as TV still under warranty but thought I would try on here encase there was a simple fix?
roliwage
Turns out, this is a huge problem for SONY TVs (which I will never buy again)
Try the steps found here:
https://www.youtube.com/watch?v=k_knSbv8oYI
and/or here:
https://www.youtube.com/watch?v=Pb1TeiJUpsU
This is just a band-aid fix, and your TV will probably screw up again. Mine did. SONY basically told me I was out of luck and denied anyone else has this problem. I feel like there needs to be a class-action lawsuit.
Sony TV won't turn on Quick and Simple Solution that works 99% of the time
How To Fix SONY TV Won't Turn ON, Red Light Flashing, Power Supply Board Problem https://youtu.be/_xF4LZP-KXg Sony Android tv stuck in boot loop. Help please! ►PROBLEMS: My Sony Android TV (kdl43w805c) has suddenly stop starting. I can see the logo sony appearing on the TV and white led starting ...
3 REPLIES 3
spannerzone
If you've tried different power sockets and power lead and no change that it looks like a TV fault unfortunately, when it works could you go into the menus to perform a factory reset to set it back to as new condition in case there's some software glitch?
roliwage
and/or here:
nesouda
Thank you and for your response,  your problem and mine have the same symptoms, like you I will not buy a Sony again.
A wee push for Amazon, they are going to refund me when I return my dead TV to them, now that's good service.
