Sony tv speaker problem
Sankaran.N
I have 43w800c and recently I used my headphones and when I unplugged and used my remote to turn volume up it showed headphone volume sign. I tried a lot but it doesn't work out , also when I again connect my headphone the headphone works but when I unplugged it tv speaker is not working please help me out guys i am waiting
2 REPLIES 2
Sankaran.N
It is due to the fact that the pin is not taken out correctly so gently wibble and it might work or else select settings go to sound and select headphones link and click off so you might a temporary relief
EdwinaU
Moderator
Hi Sankaran,
Welcome to the community.
We would recommend you contact support for advice as this sounds like it might be a hardware issue. You will find their details here.
Best wishes,
Ed
