how to use a hdr-hc7 for streaming
i have a hdr-hc7 camcordeer and want to use it as a streaming cam has anyone got any info and how to info that will help me.
any help would be appreciated
Tags (3)
1 REPLY 1
You need to connect your Camera to your computer using a capture device to get the video into your computer.
Then you would need to use some streaming software that is able to use the information from the capture device.
Peter
