Sony Bravia tv KDL-32W5810 which will not store programmes
alexmcleodnairn
I have a Sony Bravia tv KDL-32W5810 which will not store programmes. Each time it is switched on, even from stand-by, I need to re-tune it. After re-tuning all the programmes are available although the program guide does not populate. Any ideas or is it just getting old.
10 REPLIES 10
Pascale_F
Moderator
Hi Alex,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Alexmcleodnairn,
Have you tried auto tuning the TV? You can find the steps of doing this on page 100 of the Manual available through this link: https://www.sony.co.uk/electronics/support/res/manuals/ADJ5/ADJ51001M.pdf
Cheers,
The_Black_Rose
alexmcleodnairn
Yes. Auto tune is what I must do each time I switch the set on.
Sent from Mail for Windows 10
The_Black_Rose
Specialist
Hi alexmcleodnairn,
How about resetting the TV to factory settings? The steps are available on page 93 of the same manual.
Cheers,
The_Black_Rose
alexmcleodnairn
Hi again,
Yes. Tried factory settings without success I’m afraid.
Regards
Alex McLeod
The_Black_Rose
Specialist
Hi Alex,
Does the antenna work fine with a different TV? Also, I'd say that connecting a splitter or a booster might affect the signal. so, could you remove any connected boosters or splitters?
Cheers,
The_Black_Rose
alexmcleodnairn
You do not appear to understand the problem here.
When I retune the TV I get a good strength signal and all the programs are available.
But, once the set is turned off or set on standby when I power up again I get a message that no programmes have been stored.
So, I guess, the TV software is not storing the programmes.
Regards and thanks for your efforts
Alex McLeod
The_Black_Rose
Specialist
Hi Alexmcleodnairn,
Oh, I guess I got a bit confused. I've checked for updates available for this TV, and I found a software update available in the product page.
Could you try updating the software as explained here: https://www.sony.co.uk/electronics/support/lcd-tvs-legacy-lcd-tv/kdl-32w5810/downloads/Z0000302 ?
Cheers,
The_Black_Rose
alexmcleodnairn
Hi again,
This file updates all previous firmware versions to version PKG 1.740SA.
I checked set-up and found that this update has already been installed on my TV.
Looks like we are running out of options.
Regards
Alex McLeod
