Sony Channel Editor Problem
profile.country.GR.title
ROLAND_BAD
KD-43XG8196 - Sony Channel Editor Problem 1.20 V
Does not work on Windows 10 PCs
Can anyone help me
9 REPLIES 9
Marino.Manolo
If you want, and you trust ... I've realized a Portable version of Sony Channel Editor:
https://mega.nz/#!btdSFA4J!nZigkagp4pf8GjbtyMe8TdAlyEYlHCxH879EsBAEddY
Marino.Manolo
Please, remove the Sony Logo on your Avatar.. Thank's.
ROLAND_BAD
ROLAND_BAD
quello che mi hai inviato non funziona
Marino.Manolo
It works for me, have you installed Java on your PC?
Marino.Manolo
I've also version 1.1 if you want to try...
ROLAND_BAD
No....🤔   devo installare java ...
Grazie per l'aiuto e il tempo  🙏
Marino.Manolo
Actually it would all be in the Portable version but the Java installation could resolve.
Marino.Manolo
The Avatar... 🤔 👎
